Old 09-03-2018, 07:25 PM   #1
Tedtalker
Drives: 2007 Yaris Sedan
I just installed a new Dayco Poly Rib belt on my 2007 with 75,000 miles. Engine ran much better and so much smoother. I wasn't expecting a better running engine. I just thought I better replace it after 12 years and 75K. My OEM belt never squeaked or chirped ever and this Dayco Poly Rib is silent as well. Before I loosened the alternator bolts I marked around the bolt washer with a sharpie pen. Tension-ed the new Dayco at the exact marking and it seems perfect. Maybe it's the Dayco Poly Cog belts that squeal? My Poly Rib said made in USA on the belt. Good enough for me.
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
Old 09-04-2018, 06:20 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Serpentine belt tension adjustment water pump bearings
Absolutely not a way to set new-belt tension.
(Serpentine belt tension adjustment water pump bearings)
Old 09-06-2018, 08:20 PM   #3
Tedtalker
That was the factory setting dog. It was exactly where the factory tech placed it. I figured it was a good starting point before FINAL tension setting after the new belt stretch. My tension tool is on the way.
2008 Yaris knocking/rattling sound near drive belt avs262 DIY / Maintenance / Service 4 07-21-2015 05:34 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
change water pump n something is shifting susucosp DIY / Maintenance / Service 1 10-04-2013 02:23 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Squealing after water pump blew euroa4 DIY / Maintenance / Service 11 06-10-2010 03:18 PM
