Old 07-20-2015, 06:01 PM   #1
avs262
Drives: Yaris 08 sedan
2008 Yaris knocking/rattling sound near drive belt
I have a 1.3L Yaris manual transmission that is knocking/rattling near the drive belt. I've searched around on here and found that this could be caused by the water pump so I replaced the water pump and drive belt last night. The water pump did have antifreeze all around it so I thought for sure that was the problem. After replacing I fired up the engine and the problem continues. I've taken a video (https://vid.me/VLYv) so you can hear the noise - has anyone experienced this? My next step is to go buy a stethoscope. Any other ideas would be greatly appreciated!
avs262 is offline   Reply With Quote
Old 07-20-2015, 10:43 PM   #2
avs262
It turned out to be the a/c unit. I listened with a stethescope and loud knocking could be heard from the a/c. I used a serpentine belt from a non a/c configuration to bypass it until I figure out what's wrong with it.
Old 07-21-2015, 02:30 AM   #3
valchrist90731
Drives: 2007 toyota yaris sedan
But does the a.c. work when on? Does it blow cold air?
How's the pulley? That's a different noise never heard that yet.
valchrist90731 is offline   Reply With Quote
Old 07-21-2015, 04:15 AM   #4
Mikastef
Do u use the air con often..? If not, then it should not be the AC unit
Mikastef is offline   Reply With Quote
Old 07-21-2015, 05:34 PM   #5
avs262
The a/c does work when it's turned on (I don't use it often) and is blowing cool air. I will check the pulley and report back.
How many miles you got out of Yaris drive belt? waruna01 DIY / Maintenance / Service 12 06-09-2015 01:01 PM
Yaris with new audio DPS module installed - Gadget or really increasing sound quality Flyingmatdes New YARIS Purchase Forum 8 04-19-2011 12:50 AM
2008 Yaris S driving belt socjo1976 California 9 03-16-2011 05:52 PM
