Old 09-07-2018, 08:23 AM   #1
dogsridewith
Drives: 2007 2-door hatchback
Water pump serpentine belt tension tensiometer
No way. Good chance you're killing the water pump bearings. Running too tight wouldn't help the belt either. (How do you think you would be able to know too-tight by observation...when saying "seems perfect?")
By the way. The manual's serpentine belt tension treatment is a Mind of Toyota cluster-fluff. I won't recommend a method for anyone else, but mine is an initial set to not-too-tight by feel, matchmark, and tighten in tiny increments when hearing a chirp at startup. (I'd carry tools if making a trip on a new belt.)
I'm tightening by a 13 inch channel lock plier w/ jaws on the end of the curve-slot adjuster bar and the alternator's upper bolt boss. (Toyota manual wants prybar but be careful to miss the critical mechanism right there some where hard to see and same color as the other metal engine parts.)
Old 09-09-2018, 07:09 PM   #2
Tedtalker
Drives: 2007 Yaris Sedan
Thanks for the heads up. I did the 90 degree twist method after setting it where the Toyota tech set it. Seems right on but I will of course check it with my new v-belt guage when it arrives. (fFrom the Web) Place a belt tension gauge in the span shown and tighten the belt until the tension reads 102-123 ft.-lbs.
If you don't have a tension gauge, just measure the deflection of the belt in the span area shown in the illustration. When properly tightened, the belt should deflect .410 to .450 inch. I did put the wrenches in my car after the install. Just in case
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
2008 Yaris knocking/rattling sound near drive belt avs262 DIY / Maintenance / Service 4 07-21-2015 05:34 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
change water pump n something is shifting susucosp DIY / Maintenance / Service 1 10-04-2013 02:23 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Squealing after water pump blew euroa4 DIY / Maintenance / Service 11 06-10-2010 03:18 PM
