![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
d00d you can't just casually post "I installed a rotrex..." like that - thread on install and setup needed asap! lol My suggestion was going to be add a degree colder plugs, but clearly that wasn't working for you... Are you all setup to monitor air-fuel, fuel trims, etc..? Possible spark is fine and you're leaning way out? -- Adam |
#2 | |
![]() I went two degrees colder. I read somewhere that they recommend a spark plug with a heat rating of 7. Maybe I should try the 6? In that case should I go with the OEM gap of 0.044, or should I go narrower? I do have a CEL that's showing 2 codes: P2195 - Oxygen Air/Fuel Sensor Signal Stuck Lean Bank 1 Sensor 1 P0171 - Air/Fuel Mixture System Lean Bank 1 Other than the occasional knocking the car is running fine. |
| Best spark plugs for Toyota Yaris Verso ? | Jesper M | DIY / Maintenance / Service | 2 | 09-29-2016 11:00 PM |
| Changed Spark Plugs and Now Car Won't Start | VegeLasagna | DIY / Maintenance / Service | 20 | 06-24-2016 10:36 PM |
| Bigger Spark plug? | samuraivince | Performance Modifications | 6 | 08-05-2014 04:09 PM |
| gap for spark plugs for the blitz supercharger? | whooppee777 | Forced Induction Forum | 2 | 03-12-2011 01:09 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
