Old 09-26-2016, 05:12 AM   #1
Jesper M
Jesper M
Drives: Toyota Yaris Verso 1.3
Best spark plugs for Toyota Yaris Verso ?
Hi All,
I hope one of you can help clarifying this ...
As it is I'd like to replace the spark plugs in my Toyota Yaris Verso (TOYOTA YARIS VERSO (NLP2_, NCP2_) - 1.3 (NCP20_, NCP22_) (86Hk)) and in these forums have read that in general Denso and NGK is recommended.
I've also read that iridium may be preferred due to durability. However, are iridium spark plugs better/in practice much more durable or would I be almost as well off with standard spark plugs (like e.g. the Denso K16R-U11)?
Also, in case there's a clear advantage with using iridium types may you suggest a suitable type/model for this car? When I search Denso's homepage I get these suggestions:
http://www.globaldenso.com/cgi-bin/g...3.txt&no=11199
... and I wonder if all of them are suitable or if there is a preferred model?
I'm soon off on vacation and would like to replace the spark plugs first - so many thanks for help in this ...
Cheers
Jesper
Jesper M is offline   Reply With Quote
best plug, iridium, spark plugs, toyota yaris verso
spark plugs phenoyz DIY / Maintenance / Service 48 01-18-2023 02:26 PM
Location of Spark Plugs KEVBD DIY / Maintenance / Service 7 02-03-2012 11:05 AM
