Old 10-12-2018, 06:06 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Exiwolfman View Post
I did see that is available, but good luck trying to replace it on the car with out specialty tools and not braking anything...I say replace the whole hub bearing and be done with.
Sent from my EML-L29 using Tapatalk
I agree with you that replacing the whole hub assembly would be easier. I guess it's a question if you want to spend more dollars, or expend more sweat equity. I wouldn't want to think about how much an OE wheel hub would cost around here. I like to use/retain OE parts as much as possible. When my ABS light comes back on - aka, my temporary fix fails - I'll be replacing the sensor only and without 'special tools' developed by Toyota. There's usually a work around.
Can't find front hub bearing assembly with ABS anywhere! PrettyWreckless DIY / Maintenance / Service 5 04-09-2018 03:15 PM
abs rear hub assy and sensor change + new harness install. limochong DIY / Maintenance / Service 2 11-13-2014 04:58 AM
Disconnecting rear hub ABS 746watts DIY / Maintenance / Service 4 04-17-2012 03:23 PM
yaris hub and bearing assy with abs chrissy b Items for Sale by private party 8 12-12-2011 09:22 AM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
