Old 10-25-2018, 05:49 PM   #1
Did you try rotating the hub when you had everything apart?
Old 10-25-2018, 05:55 PM   #2
Pinchlite
Drives: 2007 yaris HB
NO.I was planning to remove the caliper tomorrow and do that.I will take the other side off aswell to comapre.I dont know what resistance or drag is normal.
I have never had a wheel bearing give zero symptoms before failure.There is no play and zero noise.
From what I can see though the outer pad seems tight against rotor,and the inner pad that moves in kinda lopsided.To explain better the pad retracts but mostly on the top part of pad?
If it happens to be a bearing I will replace the hub and bearing as a unit.The price is not much more for entire unit and i wont need a mechanic to press bearing in.
Pinchlite is offline   Reply With Quote
front caliper pin tunring wont' snug nambi_ DIY / Maintenance / Service 2 09-07-2018 08:34 PM
Passenger side caliper loose... baseballfan416 DIY / Maintenance / Service 5 08-17-2016 11:35 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
My Yaris with a lil' Half 'N' Half The Architect Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-18-2009 02:36 PM
Yaris half mask? kimona Cosmetic Modifications (Exterior/Interior) 1 06-14-2007 08:10 PM
