Old 05-03-2009, 06:36 PM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
My Yaris with a lil' Half 'N' Half
So I swapped out the rear springs back to stock, it was a fun time had by all.
The extra bit of height will be comforting when I carry out my plans later on but even now it looks pretty nice to me.
Before it was low low and now I think its just a tad bit high.
Feel free to comment.
PG TLD22 8V Line Driver
Old 05-03-2009, 07:11 PM   #2
1NZYaris1
1NZYaris1's Avatar
Wow Looks good , is there much of a handling differance, with the
stock springs in the back.
Old 05-03-2009, 07:13 PM   #3
The Architect
Give Me Resonance
I have no idea yet haha, I got done and was tired and wet from the mild rain.
Old 05-03-2009, 09:33 PM   #4
TitaniumBarbell
TitaniumBarbell's Avatar
Drives: Yaris 3Dr LiftBLACK
Are legal this taillights?
TitaniumBarbell is offline   Reply With Quote
Old 05-03-2009, 10:13 PM   #5
ChinoCharles
Drives: LB
Real wheels and rear spacers and BOOM you're set.
Old 05-03-2009, 10:19 PM   #6
The Architect
Give Me Resonance
spacers? What is this new concept/purpose you speak of.
Wheels coming very soon though.
& as far as the tail lights go....I havent had any problems yet in the state of FL & CT
Old 05-03-2009, 10:20 PM   #7
ChinoCharles
Drives: LB
The wheels in the back sit too far in. Rear spacers will make them pop out a little bit and be (hella)flush with the fenders.
Old 05-03-2009, 10:29 PM   #8
The Architect
Give Me Resonance
Do explain how they install so I can imagine installing them, I saw some 30mm ones on ebay for 100 bucks I think.
Old 05-03-2009, 10:30 PM   #9
ChinoCharles
Drives: LB
Not sure, never installed them. I need some too, though.
Old 05-03-2009, 10:31 PM   #10
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Looks way better, this is true for the sedan as well.
I was thinking about switching my rear springs back to stock too since its so easy to swap them out. Plus you got a little extra weight in the back cause of your subs right? Helps things even out, I know a little bit of weight in my trunk goes a long way.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-03-2009, 10:34 PM   #11
yarstar
Drives: 2008 Absolute Red HB
Get'em from Garm. Don't go above 15mm though or you may hit the fender well.
Install is relatively easy. You have to bang out the stock lugs and put in the extended lugs that come with the kit.
Makes the car look alot better.
What are those 'studs' above your spoiler? Nice ride, BTW.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 05-03-2009, 10:41 PM   #12
The Architect
Give Me Resonance
I forgot about the whole hitting the sidewall thing. Running my intended 205/40/17 that I might be soon will already be nice and cozy without the extra 15mm push.
The studs are just the carefully applied "vortex generators" there was a thread about them a good while ago. I think they work for me.
We'll see how things work out once I get the new wheels.
Old 05-03-2009, 10:44 PM   #13
ChinoCharles
Drives: LB
You'll still want spacers depending on the offset of those wheels. I ran the same size back in the day.
Old 05-03-2009, 10:49 PM   #14
The Architect
Give Me Resonance
Yeah on second thought i dont see how if my wheels clear the sidewall and i apply the spacers which push them outward where the problem would be.....in theory.
Old 05-18-2009, 01:36 PM   #15
naossoan
Drives: 07 Yaris 3DR
Hey Architect - What did you paint your wheel covers with? I wanna do that. My front ones are kinda scratched cause I curbed them once or twice. I also smoked the curb when I was e-brake turning around corners in the snow and broke a piece of it off lol.
naossoan is offline   Reply With Quote
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Yaris Boosts Starter-Car Segment ketel0ne General Yaris / Vitz Discussion 0 08-04-2006 10:16 AM
