#307 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
This is confusing because My harness is the same as yours.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-03-2018 at 10:57 PM. |
#308 |
Thanks Tom. Defintely the same configuration, but different wires. Not sure if they serve the same functions as I haven't looked at the Corolla diagrams much.
Down the rabbit hole... If I actually got a 2008 xD ECU, then it appears - in its stock form- to be incompatible with both my harness and transmission. For one thing the 2008 ECU only appears to feed 8 wires to the connector. And, the SLT+ and SLT - pins are not the same between my Yaris and the xD harness. From what I'm seeing - from my limited understanding - I need a different ECU, or figure out if the one I have will work and I need to swap some pins in the harness at the ECU. I still have to look at my ECU overall to be sure that those spots even have pins and if they are assigned to something else. I will try to refrain from asking a lot of questions as I've done an awful lot of that over the past couple months. But, feel free to chime in if you are so inclined. Once this is all over, I'll spend some time cleaning up my thread.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-03-2018 at 11:21 PM. |
#309 |
Data doesn't lie
Wow. I apologize. I wasn’t aware they changed the pins in 2011. So it looks like you need to do the same pin swap I had to at the ECM. Here is the link to how I did it:
http://www.yarisworld.com/forums/sho...t=56031&page=5 So it looks like at some point they started using corolla parts on the xD, right before it was discontinued. Great work pulling up the info! |
#310 |
Data doesn't lie
If you want to know how all of these ECTS wires work and why ill give a brief explanation. Each one of the inputs corresponds to a solenoid, these solenoids move when activated by the ECM and allow line pressure(about 800psi) to activate their wet clutches. The holding and releasing of these clutches manipulate how the planetary gears "simulate" gears.
![]() Solenoids are just an electrical load device, they need a positive and negative circuit to operate. Just like a bulb, here we're moving wires around in the harness to make those solenoid circuits complete. The Yaris ETCS has a different layout than ALL of the 1.8L cars due to its sub-compact nature. So we are never going to have a simple "plug-n-play" AT swap. |
#311 | |
It looks like I do have to swap 57 to 58. The 2008 xD does not reference Pin 9 at all. I wonder if that is why it is grounded. There is no mention of SLU+ and SLU- on the 2008 pinout. I wonder if I need a different ECU. Here is an update picture that includes a 2009 Corolla. As far the 2009 Corolla and 2011 xD ECTS is concerned, the pins are identical. I still can't get my head around the changes in the xD ECU between 2008 and 2011. I am wondering if I should just go out and do as you say - switch 57 to 58, ground 9 and test it.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-04-2018 at 08:42 AM. |
#312 |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
At work, can't play with diagrams, but given what you have there I can see your problem..
All pins trans side are consistent in function (same trans), BUT - pin 9 should be ground as Tom noted; the 2008 ECM doesn't supply an SLU-, it uses a local ground instead it looks like. At the ECM the 2008 and 2011 xD differs on pins for SLU+/- and SL. Pin 57 on your 2011 harness needs to move to pin 58 to match the 2008 ECM; you've already cut the wire at pin 77 - just make sure it's not used elsewhere and is taped and isolated to avoid issues.. -- Adam |
#313 |
Thanks Adam! I'm going to do the swaps as per Tom's and your directions. At hockey again today, so it will be a bit later. I'm going to practice removing ECU pins on my Yaris harness before tackling the xD harness in the car.
I will definitely post back with the results.
#314 |
I cannot for the life of me get these darn terminals out! I am practicing on my spare Corolla harness that came with my engine. I'm in the correct release hole, wiggling the safety pin around, the white slide lock is pushed out the required mm. Maybe my pin is too small. I've looked at a close up pic of the actual terminal.
#315 |
OK, finally managed to get a couple of pins out. How easily should they come out? It took a bit of force and made a little snap sound. The terminal appears undamaged.
#316 |
My experience is that usually if the retaining bar/clip is fully disengaged and the pin has the internal clip out of the way a bit of a gentle tug will slide it out. Generally force and a snap sound means the plastic internal clip is busted. You can check by reinserting the terminal - it will feel sloppy if broken..
Good news is you're pulling out of one and into another pin slot, so if you break the internal clip you're probably OK, as long as you don't damage the metal terminal; and/or no other terminal needs to use that pin slot. -- Adam |
#317 | |
Standby for a pic!
#318 |
A picture is worth a thousand words...
![]() Thank you gentlemen!!! It was the pin swap from 57 to 58 that cleared the codes. I had 5 - 6 starts, running 5 - 10 minutes each, a similar number of scans and not one MIL, except of course when I jumped in and fired it up without putting the intake tube back on. I got MAF error, but that disappeared after re-install and startup. I redid conduit and tape around the trans connectors and ziptied everything. It looks great. One other thing I'd like to do is slightly bend my transmission dipstick tube a touch toward to the driver's side. It's hard to get out past the upper rad hose. Here is a pic with everything (in the engine bay, at least) put back together. ![]() I am just so itching to take this bad boy for a run.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-04-2018 at 04:34 PM. |
#319 |
Virtual high five buddy!
Now get out and go for a rip.. ![]() -- Adam |
#320 | |
Gotta get all the panels and such back on.
#321 |
Data doesn't lie
Huge congrats to you sir for figuring this out!
#322 |
Thanks Tom, but it was you who figured it out originally! I was just riding on your coat tails. You guys have been simply awesome, from my initial inspiration to do the swap, down to the technical details. It's definitely a different thing to break new trail, than to copy what others have done. That said, I'm pretty happy I managed to pull it off. In my first post, I said it would be the most involved car-related project I've done, and that it was. Haha.
Now...time to start in on learning to beef up the 1NZ internals for forced induction....joking!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-04-2018 at 07:38 PM. |
#323 |
Congrats on the swap! Enjoy a much needed sleep lol
I'm surprised the 2011 harness is different then the 2008, guess we all learned something new on this swap. This is also one of the reasons I want to put out a thread going over these things.
#324 |
Thanks. Yes, I too was surprised but ultimately thankful that it just required the pin swap. Maybe a quick review of wiring diagrams before posting could confirm any other differences in the years if there are any. I could do that as a contribution.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-05-2018 at 07:14 AM. |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 12:56 PM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 10:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 10:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
