Old 11-04-2018, 02:23 PM   #11
atomic_hoji
Drives: 2018 Yaris SE 5MT
My experience is that usually if the retaining bar/clip is fully disengaged and the pin has the internal clip out of the way a bit of a gentle tug will slide it out. Generally force and a snap sound means the plastic internal clip is busted. You can check by reinserting the terminal - it will feel sloppy if broken..
Good news is you're pulling out of one and into another pin slot, so if you break the internal clip you're probably OK, as long as you don't damage the metal terminal; and/or no other terminal needs to use that pin slot.
-- Adam
atomic_hoji is offline   Reply With Quote
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 10:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 10:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
