First Drive Tonight!
Initial observations:
Much more refined feel. The engine is much smoother and the valve train is almost inaudible. The car pulls hard right up to about 6000 rpm before it shifts. Does it push you back into your seat? Not exactly, but it's definitely more potent than the 1.5. It's much more 'torquey', if that's a word. Shifting is precise. My little aging Yaris (with 180000 kms) now has an engine with around 70000 kms! Am I impressed? Damn straight! Please excuse both the mess and the crappy pic quality. ![]() I have a small exhaust clunk as the muffler, on some bumps and harder cornering is hitting the spring seat, but I think this is a quick fix when I get the exhaust work done. EDIT: The muffler is just turned a bit counterclockwise. My midpipe is in two sections (for shipping, I assume) so I just need to loosen the clamp, level the muffler and retighten. I expect that the new exhaust will allow the engine to breathe a little better. That oem muffler and piping is so tiny. The 'new' used ac compressor is virtually silent. As a major bonus, the cruise control is fully functional! So, to Tom, Trevor, Adam and Sam (not in any particular order), a huge THANKS for helping me through this!!!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-08-2018 at 01:00 PM. |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
