Old 11-08-2018, 05:04 PM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
2nd Test Drive and Exhaust Work
I went out for another drive this evening and I'm impressed. Took it out on the highway and found the steepest hill I could. I set the cruise control at 120 km/h. With the 1NZ and cruise set, it would always drop a gear. The 2ZR powers up the hill without a gear drop and not even a detectable increase in rpm. Awesome!
I was under the back of the car rigging up a bungy cord on the hanger to stop the clunking just for tonight. I had a look at the midpipe and I'm thinking I ought to have the exhaust shop chop the pipe at the resonator and upsize the pipe to the rear flange at the axle. Maybe to 2" or 2.25". I know that my muffler will be much more free flowing than the stock muffler, but I can't help but think that that midpipe is really restrictive. Taking into consideration what you have all said - and done - as well as reading a thread by 'the barber', I'm thinking this is the route to go. I've heard that a freer flowing (maybe too free-flowing) exhaust can adversely affect torque and I wouldn't want to lose any of that. Thoughts/comments welcome as always.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
