Old 11-04-2018, 09:02 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Belt tight enough?
Old 11-05-2018, 03:41 PM   #2
PowerSet
Drives: 2007 yaris 4dr sedan
Belt tight enough?
the belt was squealing a few weeks ago and was loose, retensioned it until the noise was gone, but I will check it again, I have not tested battery or alternator, battery is only about two months old, no battery light while running and it appears to start with plenty of power(when it starts)
I will try to test the alternator and battery when I can, and will re tension the belt.
PowerSet is offline   Reply With Quote
can anyone help me figure out engine code/model of 2012-2014 1.5L hybrid? funky2nite Third Gen Yaris General Discussion 2 05-07-2017 12:56 PM
FS NEW OEM TOYOTA CRUISE CONTROL UNIT FOR $50 jiroj.amaralikit Items for Sale by private party 6 12-06-2011 04:06 PM
Why a 4spd not 5spd AT CB900F2 General Yaris / Vitz Discussion 18 01-26-2009 11:01 AM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
5spd vs automatic m-arco General Yaris / Vitz Discussion 16 12-14-2006 05:32 PM
