Old 12-05-2011, 06:32 PM   #1
jiroj.amaralikit
Drives: BMW 3 Series
FS NEW OEM TOYOTA CRUISE CONTROL UNIT FOR $50
Retail Price: $94.80
The unit will fit the following:
Scion tC 2010.08- 4cyl 2.5L MTM
Scion tC 2010.08- 4cyl 2.5L ATM
Scion tC 2010.01-2010.03 4cyl 2.4L G LB
Scion tC 2004.05- 4cyl 2.4L G LB
Scion xB 2010.03- 4cyl 2.4L MTM HB
Scion xB 2010.03- 4cyl 2.4L ATM HB
Scion xB 2007.03-2010.03 4cyl 2.4L MTM HB
Scion xB 2007.03-2010.03 4cyl 2.4L ATM HB
PRIUS 2009.12- 4cyl 1.8L ATM E
PRIUS 2009.08- 4cyl 1.8L ATM L
PRIUS 2009.04- 4cyl 1.8L ATM S
PRIUS 2009.04- 4cyl 1.8L ATM G
PRIUS 2005.11-2009.03 4cyl 1.5L
PRIUS 2004.08-2005.11 4cyl 1.5L
FJ Cruiser 2009.09-2010.01 6cyl 4.0L MTM
FJ Cruiser 2009.09-2010.01 6cyl 4.0L ATM
FJ Cruiser 2008.01-2008.04 6cyl 4.0L MTM
FJ Cruiser 2008.01-2008.04 6cyl 4.0L ATM
FJ Cruiser 2006.01-2010.11 6cyl 4.0L MTM
FJ Cruiser 2006.01-2010.11 6cyl 4.0L ATM
YARIS 2009.08- 4cyl 1.5L MTM
YARIS 2009.08- 4cyl 1.5L ATM
YARIS 2008.08-2009.08 4cyl 1.5L MTM
YARIS 2008.08-2009.08 4cyl 1.5L ATM
YARIS 2008.08- 4cyl 1.5L MTM STD 5D
YARIS 2008.08- 4cyl 1.5L MTM STD 3D
YARIS 2008.08- 4cyl 1.5L ATM STD 5D
YARIS 2008.08- 4cyl 1.5L ATM STD 3D
YARIS 2008.08- 4cyl 1.5L ATM RS 5D
YARIS 2008.08- 4cyl 1.5L ATM RS 3D
YARIS 2006.02-2008.08 4cyl 1.5L MTM
YARIS 2006.02-2008.08 4cyl 1.5L ATM
Camry 2009.01- 4cyl 2.4L ATM
Camry 2009.01- 4cyl 2.5L ATM XLE
Camry 2009.01- 4cyl 2.5L ATM LE
Camry 2009.01- 6cyl 3.5L ATM XLE
Camry 2009.01- 6cyl 3.5L ATM LE
Camry 2006.03-2009.01 4cyl 2.4L ATM
Camry 2006.01-2009.01 4cyl 2.4L MTM LE
Camry 2006.01-2009.01 4cyl 2.4L ATM XLE
Camry 2006.01-2009.01 4cyl 2.4L ATM LE
Camry 2006.01-2009.01 6cyl 3.5L ATM XLE
Camry 2006.01-2009.01 6cyl 3.5L ATM LE
Camry 2004.09- 4cyl 2.4L MTM SE
Camry 2004.09- 4cyl 2.4L MTM LE
Camry 2004.09- 4cyl 2.4L ATM XLE
Camry 2004.09- 4cyl 2.4L ATM SE
Camry 2004.09- 4cyl 2.4L ATM LE
Camry 2004.09- 6cyl 3.0L ATM XLE
Camry 2004.09- 6cyl 3.0L ATM LE
Camry 2004.09- 6cyl 3.3L ATM SE
Highlander 2008.11-2010.08 4cyl 2.7L STD
Highlander 2007.05-2010.08 4cyl 2.7L STD
Highlander 2007.05-2010.08 6cyl 3.3L STD
Highlander 2007.05-2010.08 6cyl 3.3L LIMD
Highlander 2007.05-2010.08 6cyl 3.5L STD
Highlander 2007.05-2010.08 6cyl 3.5L SPO
Highlander 2007.05-2010.08 6cyl 3.5L LIMD
Highlander 2007.05-2010.08 6cyl 3.5L GD
Highlander 2005.03- 6cyl 3.3L WG
Highlander 2004.09- 4cyl 2.4L WG
Highlander 2004.09- 6cyl 3.3L WG
RAV4 2008.08- 4cyl 2.5L ATM X
RAV4 2008.08- 4cyl 2.5L ATM SPO
RAV4 2008.08- 4cyl 2.5L ATM LIMD
RAV4 2008.08- 6cyl 3.5L ATM X
RAV4 2008.08- 6cyl 3.5L ATM SPO
RAV4 2008.08- 6cyl 3.5L ATM LIMD
RAV4 2005.11-2008.08 4cyl 2.4L ATM X
RAV4 2005.11-2008.08 4cyl 2.4L ATM SPO
RAV4 2005.11-2008.08 4cyl 2.4L ATM LIMD
RAV4 2005.11-2008.08 6cyl 3.5L ATM X
RAV4 2005.11-2008.08 6cyl 3.5L ATM SPO
RAV4 2005.11-2008.08 6cyl 3.5L ATM LIMD
RAV4 2004.09- 4cyl 2.4L MTM
RAV4 2004.09- 4cyl 2.4L ATM
Corolla 2007.12-2010.12 4cyl 1.8L ATM STD
Corolla 2007.12-2010.12 4cyl 1.8L ATM LE
Land Cruiser 2007.09- 8cyl 5.7L ATM
Land Cruiser 2005.05- 8cyl 4.7L ATM
Land Cruiser 2004.09-2005.05 8cyl 4.7L ATM
Scion xD 2007.06- 4cyl 1.8L MTM
Scion xD 2007.06- 4cyl 1.8L ATM
4Runner 2005.08- 6cyl 4.0L ATM SR5
4Runner 2005.08- 6cyl 4.0L ATM LIMD
4Runner 2005.08- 8cyl 4.7L ATM SR5
4Runner 2005.08- 8cyl 4.7L ATM LIMD
4Runner 2004.09-2005.08 6cyl 4.0L ATM SR5
4Runner 2004.09-2005.08 6cyl 4.0L ATM LIMD
4Runner 2004.09-2005.08 8cyl 4.7L ATM SR5
4Runner 2004.09-2005.08 8cyl 4.7L ATM LIMD
Tundra 2004.10- 6cyl 4.0L ATM SR5
Tundra 2004.10- 8cyl 4.7L ATM SR5
Tundra 2004.10- 8cyl 4.7L ATM LIMD
Tundra 2004.10- 8cyl 4.7L ATM DLX
Sequoia 2004.09-2007.11 8cyl 4.7L SR5
Sequoia 2004.09-2007.11 8cyl 4.7L LIMD
Please contact jiroj.amaralikit@gmail.com for more detail
jiroj.amaralikit is offline
Old 12-06-2011, 10:00 AM   #2
06yarishb
Drives: 2012 Yaris HB LE
Wondering do I need to modify anything to hook up?
06yarishb is offline
Old 12-06-2011, 10:22 AM   #3
jiroj.amaralikit
The only modification you will need to make is if your steering column doesn't have a hole for the stalk then you will need to make a hole for it. Other than that is just a plug and play unit.
Old 12-06-2011, 10:58 AM   #4
Blue Beast
Drives: 2010 Yaris 3 door hatchback
Just got back from South Carolina to my home in northern VA and the drive without cruise control about killed me! I saw in other posts a detailed set of directions that looked like way more than I was willing to take on pulling the steering wheel, are bag etc. and I believe involved other things as well. Is it really just plug and play if there is a place for the stalk on the column? Any chance someone out there in northern VA knows of a shop I can trust for some help on this? The Manassas Toyota dealer said it was not doable on my 2010 Yaris which seemed very hard to believe!
MI Crank Pulley
DC Sports Header
TRD Stainless Sport Exhaust & TRD HP Air Filter
TRD Sport Shocks, TRD Lowering Springs, TRD Rear Sway Bar
MOTEGI RACING MR121 RIMS 15 x 7, Kumho Ecsta RSX 205/55/15
TWM Short Shifter, Base & Cable Bushings, Weighted Hybrid Shift Knob
VG Shark Fin Antenna, De-badge factory emblems, TRD Black Chrome Badge
Blue Beast is offline
Old 12-06-2011, 11:06 AM   #5
jiroj.amaralikit
Here are pictures step by step instruction on how to install the unit
It is just a plug and play type of installation other than making a hole in the steering column if it doesn't have one.
Old 12-06-2011, 04:15 PM   #6
Here is my complete DIY for installing Cruise Control on a 2006 or newer Yaris. The pictures above are not of a Yaris, so it is a bit different. Also, the stalk as shown above is not completely plug and play on a Yaris, since the Yaris routes the horn through the 4 pin connector. Also, on 2006-2008 Yaris the stalk will not work without adding the additional wiring from the ECM to the steering column. And, the ones that I sell for $40 are modified to include the horn wiring, making installation easier.
http://www.yarisworld.com/forums/showthread.php?t=33750
CTScott is offline
Old 12-06-2011, 05:06 PM   #7
jiroj.amaralikit
cruise control, oem
Toyota recalling 1.53 million cars globally fnkngrv Off-topic / Other Cars / Everything else Discussions 2 10-21-2010 03:26 PM
Dealers are refusing to install cruise control xenu General Yaris / Vitz Discussion 12 07-17-2010 01:49 AM
TW or FS: OEM Toyota T-Sport wheels 17x7 w/ tires Cosworth Items for Sale by private party 17 05-04-2010 03:08 AM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 06:40 PM
