Old 11-05-2018, 10:36 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Sounds like a voltage drop somewhere. I would check the battery connections as mentioned, and that the 2 cables attached to the positive cable are tight. Also make sure the larger ground cable is attached to the transmission.
Old 11-06-2018, 10:31 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by ArmstrongRacing View Post
...and that the 2 cables attached to the positive cable are tight.
Hmmm, where have I heard about the before?
can anyone help me figure out engine code/model of 2012-2014 1.5L hybrid? funky2nite Third Gen Yaris General Discussion 2 05-07-2017 12:56 PM
FS NEW OEM TOYOTA CRUISE CONTROL UNIT FOR $50 jiroj.amaralikit Items for Sale by private party 6 12-06-2011 04:06 PM
Why a 4spd not 5spd AT CB900F2 General Yaris / Vitz Discussion 18 01-26-2009 11:01 AM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
5spd vs automatic m-arco General Yaris / Vitz Discussion 16 12-14-2006 05:32 PM
