Old 10-21-2018, 03:18 PM   #1
DarkShadowFox
DRUM BRAKES
*science garage screaming* DRUM BRAKES.
Discuss all Drum Brake things here.
Old 11-05-2018, 12:50 PM   #2
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
DUMB BRAKES.
But seriously, the only reason why manufacturers still use them is because they're cheap, and they do the job. I don't like cleaning them, and I don't like replacing them. Disc brakes rule.
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 11-05-2018, 01:07 PM   #3
Leegamer
Leegamer's Avatar
Originally Posted by deng View Post
DUMB BRAKES.
I've never really messed with them, the yaris is the only car I've ever owned with drums. I'm assuming on a car as light at the yaris that they last quite a while.
I got 150k miles out of my factory brake pads on the front. I guess I should have a look at the drums.
Old 11-06-2018, 06:27 AM   #4
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
They don't oxidize when your parked outside and it's raining
Fluxtasy is offline   Reply With Quote
Old 11-06-2018, 06:57 AM   #5
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
But they will seize on if allowed to. I always leave the handbrake of after washing the car, more in winter.
I had a problem last winter when the drums must have frozen onto the drum. It was a nightmare trying to free them. Eventually achieved by driving forwards and backwards on my street. Must have lookd a bit strange to an observer.
It threw up ABS and Traction fault warning lights and stored trouble codes them.
Although it's doubtful you will have that problem in Malaysia.
mrpj is offline   Reply With Quote
Old 11-06-2018, 09:18 AM   #6
Fluxtasy
feed my pet
Fluxtasy's Avatar
Yes it's just hot and rainy all year round
Old 11-06-2018, 04:08 PM   #7
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
DUMB BRAKES.
+1
Old 11-06-2018, 11:33 PM   #8
91mustang
Drives: Charcoal 2012 Yaris SE 5 Speed
I dont like them. I try to convert them if i have them on a car.
91mustang is offline   Reply With Quote
Old 11-07-2018, 11:44 AM   #9
nortonfb
Drives: 2007
You can't beat a drum...er well maybe.
nortonfb is offline   Reply With Quote
Old 11-07-2018, 05:20 PM   #10
DarkShadowFox
you can beat off a drum
page 2 by me
Old 11-07-2018, 06:11 PM   #11
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
Zero Drag and a self adjusting parking brake.......for a car as light as the Yaris they are perfect.
As long as I never have to change them or take them apart. ;)
Ronnie V is offline   Reply With Quote
Old 11-09-2018, 12:32 PM   #12
DarkShadowFox
OFF TO DISCS FOR ME.
Old 11-09-2018, 02:10 PM   #13
Runethecursed
Drives: 2009 Yaris S
well i know from experience. any sort of modifications to the master/booster/ front calipers throws the braking feel way off, and the drums are sorta.... inferior to all those
Runethecursed is offline   Reply With Quote
Old 11-10-2018, 02:35 PM   #14
DarkShadowFox
thats why you replace it with SE stuff so it doesnt do that.
the stuffs not expensive you just need to pull wrecker parts.
Old 01-12-2019, 11:05 PM   #15
JDJanitor
Drives: 2016 yaris
How do we make the drums adjust? Drive in reverse and pull parking brake?
Sent from my moto x4 using Tapatalk
JDJanitor is offline   Reply With Quote
Old 01-13-2019, 09:05 AM   #16
dogsridewith
Drives: 2007 2-door hatchback
drumbrake self adjusters star wheels
Make a lot of foot brake stops in reverse, or adjust the star wheels. Search and read lots of info on this here in yarsisworld.
One peculiarity of the 2nd gens is that a number of reports indicate the self-adjusters don't work very well. (Handbrake develops a lot of clicks.)
Old 01-14-2019, 10:26 PM   #17
JDJanitor
Drives: 2016 yaris
With a truck it's easy just to climb underneath and hit the star adjusters, but the Yaris is a little shorter to the ground. I was hoping there was a way to easily adjust them automatically going reverse and pulling the parking brake or going in reverse and hitting the foot brake maybe. Mine's a 2016 if that makes any difference.
I'll try going reverse and stopping a few times see if that shortens pull of the parking brake
Old 01-15-2019, 05:36 AM   #18
dogsridewith
Automatic adjusters drum hand parking foot brake
The guy here who did it that way said it worked with a lot of stops, not a few. It could be the handbrake works better than footbrake, or worse, or not at all. Since the fronts aren't helping, the rears do all the work. But the clever invention couldn't expect people to stop in reverse with the handbrake.
+1 on hard to reach the star wheels from behind. But the drum usually slides right off...Tercel still required bearing disassembly, I recall.
I like to inspect shoes, de-dust, and scrape rust from the edge that can form w/ high miles/use in salt spray.
whistle noise from tyres/rear drum brakes monkeydave Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-16-2017 02:19 PM
drum brakes make squeaky noise jack black DIY / Maintenance / Service 5 08-17-2014 06:45 PM
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-17-2010 11:39 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
