Old 08-17-2014, 01:21 PM   #1
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
drum brakes make squeaky noise
This is my kid's 07 yaris with about 70,000 miles. This is a new noise, not very loud but clearly audible (with radio off). Not when you apply brakes, but when you release them. Clearly in the rear. Recently I checked the front disk brakes and the pads had about 50% wear (unknown mileage). The brakes work fine otherwise.
I never enjoyed working on drum brakes (I did it only twice that I remember, never on this car), are they out of adjustment or something more serious?
Thanks!
jack black is offline   Reply With Quote
Old 08-17-2014, 02:06 PM   #2
nortonfb
Drives: 2007
I would suspect moisture. I would pull the drums , lube the contact points and adjust.
You can lube the contact points with a small screwdriver & avoid disassemble y.
Steve
nortonfb is offline   Reply With Quote
Old 08-17-2014, 02:55 PM   #3
bail_w
Drives: 2007 Toyota Yaris LB
Clean the dust off the drum if you have not done it yet.
bail_w is offline   Reply With Quote
Old 08-17-2014, 03:13 PM   #4
jack black
jack black's Avatar
Thanks.
I'll try to find some tutorials on YouTube as I'm a bit rusty on this.
Old 08-17-2014, 04:12 PM   #5
jack black
jack black's Avatar
I couldn't find a video on Yaris, but found one on older corolla and echo, should be similar. Wow, no axle nut holding the drum and no need to take bearing apart? That's easy job. Will do it soon when it stops raining.
Old 08-17-2014, 06:45 PM   #6
Clean and lubricate friction points.
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Speakers make noise when engine is on Lafiro In Car Entertainment + Electronics (audio / video / alarm) 13 01-07-2009 08:52 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
