Old 11-07-2018, 07:37 PM   #1
Saint
Saint
Drives: 2011 toyota yaris
Loose relay in the engine compartment.
Hi everyone.
I have a 2011 yaris hatchback.. I noticed a loose relay inside my engine compartment and was wondering if anyone knew where it is to be fixed. The model number of the relay is MB141967 Hate to see that dangling loose. it was tucked away behind the fuse box but I am sure it is to be bolted somewhere .
Sure would appreciate the help Thanks.
Saint is offline   Reply With Quote
Old 11-08-2018, 02:44 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
A picture of the relay would help.
Old 11-08-2018, 03:58 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
A check of the part number showx it to be a general purpose 30 amp relay.
It's most likely been added by a previous owner at some stage. Any non original lights or an aftermarket alarm system?
Old 11-09-2018, 06:03 PM   #4
Saint
Saint
Everything is original. It was tucked away behind the battery, and when i removed the battery to clean some leaves that got in there, I found this. Just wanted to know where it was bolted on to so that I can put it back right there.
Old 11-09-2018, 06:22 PM   #5
Saint
Saint
Will try to post one soon.
Old 11-13-2018, 11:45 AM   #6
Saint
Saint
[IMG]C:\Users\singulurir\Desktop[/IMG]
Not sure how to post an image from my desktop. HELP !!
Old 11-13-2018, 06:59 PM   #7
Saint
Saint
Here is the picture of the relay.
Old 11-13-2018, 11:58 AM   #8
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
http://www.yarisworld.com/forums/showthread.php?t=11114
Click here to see how to post pics.
Leegamer is offline   Reply With Quote
Old 11-13-2018, 07:02 PM   #9
Saint
Saint
Thanks for the directions.
Old 11-14-2018, 02:37 PM   #10
IllusionX
That's definitely not OEM.
Old 11-14-2018, 02:50 PM   #11
Leegamer
Leegamer's Avatar
Where are the wires going to? That looks like a generic relay to me.
Old 11-14-2018, 03:14 PM   #12
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
where was it found
DarkShadowFox is offline   Reply With Quote
Old 11-14-2018, 03:29 PM   #13
Originally Posted by DarkShadowFox View Post
where was it found
Stated in original post. Behind the engine bay fuse box.
Somebody go check their car and see if they can spot one. I'd do it myself but currently don't have access to mine.
Old 11-14-2018, 09:03 PM   #14
zimmer
Drives: 2011 Yaris Sedan
Sounds like for a mod for me either.
zimmer is offline   Reply With Quote
Old 11-16-2018, 09:41 AM   #15
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Upgraded horn? Towing lights? DRL bypass? It's aftermarket, no way of knowing what it goes to without tracing the wires. =)
Old 11-16-2018, 03:56 PM   #16
praivo
Drives: 2000 SCP10, 2001 NCP13
Definitely a mod. I found a wire in my car going from the battery to the tail lights, apparently one of the previous owners thought that the indicator circuit wouldn't handle a trailer and decided to use a relay. It does work, though, so I'll just leave it in there for now.
praivo is offline   Reply With Quote
Old 11-16-2018, 06:20 PM   #17
Saint
Saint
it just disappears in to the wiring harness. There are no extra lights or any such aftermarket stuff on the car. its pure stock. I bought it from a lady who used it very sparingly. Just felt that maybe someone knew what it was for, and where it would have been mounted on. I found it behind the fuse box in the engine bay.
Old 11-16-2018, 06:45 PM   #18
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Have you thought of removing it temporarily to see if something stops working?
DIY - Exterior lights on when doors are remotely unlocked CTScott DIY / Maintenance / Service 21 07-31-2025 06:30 PM
For those curious about the 1.0 1KR-FE engine dj92 General Yaris / Vitz Discussion 0 09-29-2018 06:33 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
Something loose in the engine. Swallow General Yaris / Vitz Discussion 39 05-27-2009 10:14 PM
Q about Routing wires to the engine compartment W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 10 11-01-2006 07:36 PM
