![]() ![]() ![]() ![]() Drives: street-legal go-kart Join Date: Oct 2008
thanks for the confirmation! i could barely get the hammer up there to tap on it- i can hardly imagine trying to get two bolts undone(at least not without the engine out
I'm pretty sure if you remove the plastic covers under there, you'd have good access. They are a straightforward removal and install. I think four 10mm bolts near the front and a few push pins farther back.
| Starter Plastic Cover Part Number | CT_11_Blue_HB | DIY / Maintenance / Service | 4 | 06-27-2018 08:47 PM |
| Remote starter recommendation and questions | GrayYaris | DIY / Maintenance / Service | 3 | 05-30-2014 01:06 PM |
| diy factory aux location with aftermarked hu | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-28-2008 10:38 PM |
| starter kill & horn help | spechuy | DIY / Maintenance / Service | 0 | 10-20-2008 01:30 PM |
| Starter dragging | YarisTom73 | DIY / Maintenance / Service | 5 | 08-27-2007 12:11 PM |
