Old 11-30-2018, 06:40 AM   #1
tmontague
tmontague's Avatar
There are not any realistic middle jack points in the yaris dye to it only having 3 engine mounts and no support beam underneath. If you somehow miraculously have a jack that can reach the large bolt under the doggone mount at the subframe then that is fine to use as a jack point.
Otherwise I personally use the side frame rails which will lifts both the front and rear. I then place one jack stand under the subframe rail in the front and under one of the bolts for the small support bats in the rear. I put towels on the jack stand so it doesnt scratch the frame and lead yo rust.
I'd highly recommend not using the pinch welds to support the yaris. They are only meant for road side emergency purposes and constant use will lead to them rolling over and rusting between all those layers.
Old 11-30-2018, 07:02 AM   #2
vinooooo93
Drives: Toyota Yaris 2006 Sedan
Thanks for that!
Do you have any photos / diagrams of where you suggested to jack and place the stands? I'm not too sure where those are (sorry, still new to this)
I have tried using the pinch welds but like u mentioned, Im worried they may bend and rust over time
vinooooo93 is offline   Reply With Quote
Is a 2006 Yaris coupe different from a 2007 Yaris coupe? fuzzybabybunny General Yaris / Vitz Discussion 0 02-25-2016 07:09 PM
Are there alternative jack stand spots? (08 Yaris) Silverkarn DIY / Maintenance / Service 4 11-10-2015 06:33 AM
Does the Toyota Yaris come with a jack? RMcG Third Gen Yaris General Discussion 7 08-20-2015 11:03 AM
