Old 12-07-2018, 08:35 PM   #1
Stretched tires are dumb.
If you lower the car, you will likely rub.
Old 12-08-2018, 03:39 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
How you want your car to look is a personal choice. If you want a particular look, go with it, but be prepared to put up with any negative effects from it.
Stretched tyres are very popular in drifting circles. They wouldn't be doing it if it didn't work for them, but maybe the tyres they are using are made to be used on wider rims.
Most tyres are designed to fit a certain rim width, and the makers generally have listings of what size rims the tyres are designed for, as well as recommended maximum and minimum recommended rim widths. Stretched tyres will probably wear unevenly with the sides of the tread wearing faster. The grip levels could also be affected. If you are gojng to go this route, try and find a tyre shop that has experience with stretched tyres to see what brands and sizes they recommend.
Old 12-08-2018, 04:09 PM   #3
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
+1
Ronnie V is offline   Reply With Quote
Old 12-08-2018, 04:22 PM   #4
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
Originally Posted by Ronnie V View Post
+1
+2
DarkShadowFox is offline   Reply With Quote
Old 12-09-2018, 06:17 PM   #5
KurtRS
Drives: 2005 Echo RS 2D Hatch
Apparently I need to change how this is written.
175 series tire is almost 7 inches wide. So using the word stretched is not really what I am doing. I like the tread to be a little less then the rim width.
I would go coil overs so likely would only go down an inch.
The main focus of this post was to get the overall diameter the same as factory.......
KurtRS is offline   Reply With Quote
Old 12-09-2018, 09:22 PM   #6
suprf1y
suprf1y's Avatar
Drives: 05 Echo
https://www.tacomaworld.com/tirecalc
suprf1y is offline   Reply With Quote
Old 12-09-2018, 11:08 PM   #7
KurtRS
Originally Posted by suprf1y View Post
This is the same as the tire calculator I use. Does not take into account the rim width.
This is why I was picking this tire size. Think I would lose the 1% bigger diameter in the sidewall with the wider rims.
https://www.willtheyfit.com/index.ph...7-5&offset2=30
7.5 too wide? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 09-15-2018 09:04 PM
Can it fit?? 17 - 7.5 ET 35 Mad$ Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-24-2018 06:22 PM
XXR 508 18 x 7.5 JumpmanYaris Items for Sale by private party 35 09-08-2011 06:37 PM
enkei nt03+m 17x 7.5 turboyaris Items for Sale by private party 2 01-19-2009 01:27 PM
RIn 7.5 Vs 7.0 Rudeshady Central and South America 2 12-21-2008 01:51 PM
