Got a 91 Corolla about 2000 and the A/C worked at first but faded to nothing in a year or two. When I did the full system delete, I found at least one of those skinny O-rings mis-seated...it explained the dusty oil film that would appear on the passenger side headlight.
#2 | |
#3 | |
I do basically like/believe in A/C for cars, and would likely keep the Yaris' there and working. re: your O-ring photos. Mine were thinner, the joint was different, and one of the rings was a bit rolled out of place. Last edited by dogsridewith; 12-11-2018 at 06:42 AM. |
#4 | |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
