Old 12-09-2018, 09:34 AM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by dogsridewith View Post
Got a 91 Corolla about 2000 and the A/C worked at first but faded to nothing in a year or two. When I did the full system delete, I found at least one of those skinny O-rings mis-seated...it explained the dusty oil film that would appear on the passenger side headlight.
Thanks! I thought very briefly about doing an A/C system delete, but quickly dismissed the idea. I'm much more tolerant of cold than heat. I bet a delete would free up a tiny bit more power though, even when the system isn't engaged. Did you just get rid of yours because of the hassle of repairing/maintaining it?
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
