Old 12-22-2018, 08:32 PM   #1
tmontague
tmontague's Avatar
So either your compressor is bad again (doubtful) or the way you are jumping it is not a sure guaranteed way to run the compressor (only ewd's would show that)
Or the way you are adding in refrigerant is not working property. Either it's being done wrong or something wrong is going on. Possibly an issue with manifold gauges?
Old 12-22-2018, 09:25 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks Trevor. I'll post in a sec....
BTW, I could not see any differences in the schematics between the 2008 xd and my '06 Yaris.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
