Old 12-09-2018, 06:17 PM   #1
KurtRS
Drives: 2005 Echo RS 2D Hatch
Stretched tires are dumb.
Apparently I need to change how this is written.
175 series tire is almost 7 inches wide. So using the word stretched is not really what I am doing. I like the tread to be a little less then the rim width.
If you lower the car, you will likely rub.
I would go coil overs so likely would only go down an inch.
The main focus of this post was to get the overall diameter the same as factory.......
KurtRS is offline   Reply With Quote
Old 12-09-2018, 09:22 PM   #2
suprf1y
suprf1y's Avatar
Drives: 05 Echo
https://www.tacomaworld.com/tirecalc
suprf1y is offline   Reply With Quote
Old 12-09-2018, 11:08 PM   #3
KurtRS
Originally Posted by suprf1y View Post
This is the same as the tire calculator I use. Does not take into account the rim width.
This is why I was picking this tire size. Think I would lose the 1% bigger diameter in the sidewall with the wider rims.
https://www.willtheyfit.com/index.ph...7-5&offset2=30
7.5 too wide? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 09-15-2018 09:04 PM
Can it fit?? 17 - 7.5 ET 35 Mad$ Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-24-2018 06:22 PM
XXR 508 18 x 7.5 JumpmanYaris Items for Sale by private party 35 09-08-2011 06:37 PM
enkei nt03+m 17x 7.5 turboyaris Items for Sale by private party 2 01-19-2009 01:27 PM
RIn 7.5 Vs 7.0 Rudeshady Central and South America 2 12-21-2008 01:51 PM
