Old 12-09-2018, 08:44 PM   #1
dogsridewith
Drives: 2007 2-door hatchback
Originally Posted by 06YarisRS View Post
Thanks! I thought very briefly about doing an A/C system delete, but quickly dismissed the idea. I'm much more tolerant of cold than heat. I bet a delete would free up a tiny bit more power though, even when the system isn't engaged. Did you just get rid of yours because of the hassle of repairing/maintaining it?
A/C delete during headgasket replacement at 150k on a car that was pretty well on the way to dying of rust. System was more of an add-on than w/ Yaris, which doesn't have the extra fan. Really cleaned up the engine compartment, which is busier than the Yaris' for other reasons too. (The 4AF series was originally an inline engine, and there was extra-bracket madness to make it work FWD, so the delete removed the belt and a bracket.) On A/C deletes I also remove the evaporator from the HVAC box, which makes the fan's output higher.
I do basically like/believe in A/C for cars, and would likely keep the Yaris' there and working.
re: your O-ring photos. Mine were thinner, the joint was different, and one of the rings was a bit rolled out of place.
Old 12-10-2018, 09:57 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by dogsridewith View Post
A/C delete during headgasket replacement at 150k on a car that was pretty well on the way to dying of rust. System was more of an add-on than w/ Yaris, which doesn't have the extra fan. Really cleaned up the engine compartment, which is busier than the Yaris' for other reasons too. (The 4AF series was originally an inline engine, and there was extra-bracket madness to make it work FWD, so the delete removed the belt and a bracket.) On A/C deletes I also remove the evaporator from the HVAC, which makes the fan's output higher.
I get ya. Sometimes it's not worth spending the money and/or effort on repairing non-critical systems on older cars. I've vowed to get mine working. I think I'm going to replace the condenser as they're relatively cheap and mine has some dark spots along the top. It's entirely possible that it's just rustrpoofing that I applied that leaked down from the upper crossmember. But, I've got the front off and replacing the condenser should eliminate one more possible leak point in my diagnosis. Plus, replacing it looks like a pretty quick job.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
