Old 12-19-2018, 01:53 AM   #1
toyotavios_11
Drives: Toyota Vios
i have the same problem to remove right hand side control arm bolt which is blocked by oil pan. can someone enlighten me?
toyotavios_11 is offline   Reply With Quote
Old 12-19-2018, 09:53 AM   #2
tmontague
tmontague's Avatar
You need to jack up the engine slightly on the passenger side which will give you clearance to remove the through bolt from the control arm.
You will have to unbolt the passenger side motor mount to do this and use a block of wood under the oil pan when you jack it up
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
