3 Yaris and counting..
I had that problem during my 2zr swap. Put the engine back in before the control arm then couldn't get the control arm bolt in. I ended up lowering the subframe a bit. Backed the bolts out a bit on the left side and completely removed the right side bolts while supporting the subframe with a jack. That gave me enough room to get the front control arm bolt in. That was easy for me cause I already had the subframe out and knew the bolts wouldn't give me any problems.
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Are the optional airbags worth it ? | avenno2g7 | General Yaris / Vitz Discussion | 46 | 12-07-2008 02:40 AM |
