#1 | |
One synthetic I do did buy occasionally, and will still buy when it goes on clearance at Walmart USA is the SuperTech Full Synthetic. The last 6 jugs I bought, I think i paid $12.00 a jug for. According to some reports it's not a superlative looking oil on paper - with a relatively low TBN - but fares really well in UOAs. As for the spin on filter, at some point I expect that I might add a sandwich plate and gauges since I can't get this data from OBD. And, in the unlikely event that I decide to significantly ungrade the 2ZR performance, this would obviously come in handy.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 01-16-2019 at 10:16 PM. |
#2 | |
In the middle of summer coolant will typically be 188-194F on the highway and oil around 212F. In stop and go traffic mid summer coolant peaks around 212F but tends to stay at 202F and oil around 220F max. During 45min track session coolant stays between 220 and 235F and oil gets up to 265-290F. I run off the shelf syn oil in all my cars simply due to the really cold winters here and how much easier it is to start them. Even my awd Vibe, gets 0w30 and syn gear lube in the differential. I have found the morning start ups much smoother, especially up North at the cottage after it sits over night. It's true that a dino 5w30 would still be pumpable at these temps, but a syn oil is that much less viscous and easier to pump, meaning easier to start and faster and better lubrication. I just wait until they are on sale and typically find 5L jugs for around $37. I use syn oil in my car for obvious reasons. I wouldn't trust a dino oil at 290F and under high rpm for 45 mins. I have very little burning off of oil even with the summer filled with track days, likely due to the lower volatility that syn oil has. i am interested to see how my coolant and oil temps stack up this summer without a condenser in front of my rad, a now much larger grill and a dual pass radiator. I would expect coolant to stay below 220F but as for the oil I'm not too sure.
| Need 07 Sedan Tail Light wiring info ASAP | atebit | General Yaris / Vitz Discussion | 3 | 09-07-2013 06:48 PM |
| Swap sedan tach into liftback | GrassrootsMS | DIY / Maintenance / Service | 17 | 09-26-2007 09:45 AM |
| thinking about buying the sedan. is it worth the extra money for the s(optB) version? | friedbbq | General Yaris / Vitz Discussion | 14 | 05-20-2006 12:53 PM |
