Old 01-15-2019, 04:57 PM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by tmontague View Post
The spin on conversion really has no benefit unless you need/want to run a sandwich adapter for gauges.
I actually prefer the original set up as it makes it much easier to view the filter and any particulates that were caught.
I do run off the shelf full synthetic oils, the current sample I'm waiting on is Pennzoil ultra platinum 5w30 and my past UOA's were with Mobil 1 0w30. Unfortunately PUP and even PP isnt available locally in a 40 weight so I'll be switching to something else.
I have so far had no reason to need a boutique brand oil that costs much more. Even grade III synthetics are very stout oils and can easily compare to many IV's as they just have that many more additives to make up for it.
The next oil I have been eyeing in Canadian Tire's Formula 1 (made by Shell) as they have a 0w40 euro spec. The Euro specs have a much higher HTHS due to their use of the autobahn. This obviously pairs well with my track use.
Overall temp of a full syn oil isnt really the issue - it is the cause of the issue. If the oil thins too low then lowering temps can help that. Alternatively you can run a higher weight oil that will maintain factory spec viscocity at those higher temps. The 2zr is a factory spec'd 20 weight oil in NA but a 30 weight in hotter climates (allegedly) this is based on 212F summer oil temps of normal use. Based on my research a 40 weight should bring me closer to those viscocities at 260-280F I typically run at on track
Great explanation. I have done quite a bit of reading over the past few years at BITOG. I used to always buy synthetic, but have since returned to conventional. I'm always monitoring my coolant and oil temps in my van as Kia makes many more sensors available than Toyota. I can't get oil pressure, however. After driving for a bit, oil temps are usually ~10 - 15 degrees higher. If I apply the same logic to my Yaris, even under extreme conditions - such as bumper to bumper traffic in August - there would never be a need for anything other than an API conventional. In my old Dodge grand Caravan, I installed a homebuilt tee and monitored both oil temp and pressure with cheap electrical gauges. I also tapped the transmission lines for both a Magnaflow and temp sensor.
One synthetic I do did buy occasionally, and will still buy when it goes on clearance at Walmart USA is the SuperTech Full Synthetic. The last 6 jugs I bought, I think i paid $12.00 a jug for. According to some reports it's not a superlative looking oil on paper - with a relatively low TBN - but fares really well in UOAs.
As for the spin on filter, at some point I expect that I might add a sandwich plate and gauges since I can't get this data from OBD. And, in the unlikely event that I decide to significantly ungrade the 2ZR performance, this would obviously come in handy.
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 07:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 10:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 01:53 PM
