3 Yaris and counting..
Not even easy to find a scrapped xd here in toronto. Theyre just not that popular. I got lucky with the high mileage donor I found. I do suggest to keep an eye open for one if you're thinking of the 2zr swap. You'll get everything you need for your swap ( less the '08 ecu) right down to the hoses and harness brackets. Plus bigger brakes and all suspension components (which is really only useful if you plan to raise the car slightly)
#2 | |
![]() ![]() ![]() Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
Yeah, that would be great but I've never seen an XD on the road around here let alone in the yards. My plan would be a low miles corolla then Ebay for the rest. The swap threads here a really good. I've done a civic back in the day but haven't even thought about the yaris until recently it is starting to grind in 2&4 and so may need transmission work. If I got to pull the engine for that, might as well swap it cause 358K is getting up there even for a Toyota. It's still original clutch too. |
#3 | |
Here's a listing for a '14 Corolla being parted out in Hampton: https://www.kijiji.ca/v-auto-body-pa...ationFlag=true
#4 | |
Thanks, I have that saved already. I saw you were a fellow NB'r and was going to hit you up for advice when swap time came. I won't be doing that until my engine dies enough and that could take 100K more based on past history with Toyota. or if I come accross some extra $$ |
#5 | |
Best of luck with your project. It sounds really cool.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 03:13 AM |
