![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
Just a small update. The latest MCM video provided a little motivation and I thought it was about time I made some progress. So I went and bought another Yaris..
![]() The plan is to strip the motor and gearbox out of this one so I can test fit the 2zr and EC60 into this chassis, wire it all up, sort the shifter cables and exhaust, and then transplant it all into the other Yaris. Soo...anyone in Sydney want to buy a 1NZ motor? :) |
Nice!
Yeah it's a lovely looking piece of work :)
Unfortunately I haven't installed it yet. I'll be ripping the accelerator pedal out of this new Yaris and swapping it onto that pedal before installing it in my car. After driving a manual corolla over the Christmas break, it's really highlighted how bad the pedal positions are in the Yaris. I may even take the blow torch to stalk of the pedal to try and move the position a further 10 - 20mm closer to the brake pedal. |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Following this thread closely, as far as I know you are the only one tackling a 2ZR-FE on a 3rd gen. So far it doesn't seem much different than doing the swap on a 2nd gen Yaris/Vitz
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
More progress today. Motor and gearbox have been test fitted to my spare shell and I've wired up 99% of the fuse box connector. What I can confirm so far
Now on to the wiring
That's it for now. Next steps will include getting shifter cables made up, grafting the Corolla exhaust to the Yaris one, and finishing off the wiring odds and ends. ![]()
2ZR swap. DO IT! Ask how!
Awesome work!!
![]() Drives: Toyota Echo Join Date: Oct 2016
Exciting stuff can't wait to see it. Maybe in person would be great
#8 | |
While installing the motor on the weekend I also noticed the 2zr water pump had been leaking. Seems to be a common problem so will be replacing that while I'm at it. I'm also thinking about putting the spin on oil filter adapter while I'm at it. And...after investigating custom shifter cables, I'm now investigating options to buy the genuine Toyota cables. Could be a long wait. Oh, and I'll have to re-upload new images of the wire mapping. There are some errors in my previously posted images. |
Small but exciting update. I've managed to get my hands on genuine GRMN shifter cables that match my gearbox. Buying genuine ended up costing the same as what custom cables would have.
Note, these cables are made in Belgium. No surprise there given where the GRMN Yaris is assembled (France). The cables are around 30mm longer than the ones I'd purchased from the UK that were from the 6 speed diesel Yaris. Not surprised either given the 2zr is mounted forward and down. In other news, the ZRE152 computer appears to be incompatible with the 3rd Gen systems. More to come on that, but doesn't look like I'll be using the original engine I bought.
![]() Drives: 5D YR 2012 Auto Join Date: Aug 2020
Any updates with this? So keen to see your progress. I'm also in Aus and own an auto 2012 Yaris YR and wanting to do something similar one day. Good luck!
4AGE Vitz
Drives: '01 Vitz RS, '08 Vitz RS Join Date: Dec 2018
You are an inspiration to me.
I am on my second vitz now. I had a NCP13 Vitz RS now I have NCP91 Vitz RS. My plans were to swap a 2zr engine and use my extra 6 speed transmission from my AE111 Levin for better acceleration but then I realized that the 2zr transmission bolts up to the 1NZ engine so now I am trying to confirm if the mounting points for the C50/56 NZ/ZR is the same as the C66/EC6x boxes. Thanks. Kimo |
That's a good question. I'm pretty sure that the EC6X gearbox requires completely different brackets from the C5X gearboxes. The casting is two pieces, not three and has a different configuration for the shift lever. It might require sourcing mounts from Europe or Japan to use the EC6X. Please let us know (in a new thread) what you find out!
Glad I'm inspiring someone :)
You'll likely find that the chassis mounting points for the C5X and C6X boxes will be pretty similar or at least have bosses in the right spot to tap. Would pay to do your research though. The EC6X boxes will unlikely bolt in to the NCP9X or NCP13X chassis while mated to the 1NZ unless you went custom mounts. I was mulling this over myself when I found out my 2ZR was going to be incompatible with the NCP131 - I wanted to make sure I could still use my EC6X box with the Quaife. However, I've since acquired yet another Corolla/Scion IM, which I know for a fact will work, and am now in the process of piecing all that together. The 2zr dream lives on. For the record, anyone considering doing a 2ZR swap in to a 3rd gen should probably think twice before committing to it. You must use a 2ZR and some of the other gear from a ZRE18X (Corolla/Scion IM). It's no where near as simple as the NCP9X swap. |
#14 | |
What did you find out with the LSD in the EC6X gearbox? |
#15 | |
The last few months have been frustrating to say the least when I found out that the older 2ZR ECU was simply not compatible with the 3rd gen systems. While it would have driven, there would have been multiple systems and sensors that would not have functioned. Funny, the immobiliser did register with the ECU, but that was about the only good news. Therefore, I started mulling over whether to try and install the EC6X with the 1NZ. I didn't spend too much time on that though. I'm now onto a 2013/2014 Corolla that comes with an updated ACIS based intake manifold. We got that version here in Aus while you guys in NA got the Valvematic version. Unfortunately for me, the ACIS manifold is another 30%ish larger and doesn't clear the radiator fan shroud. There are workarounds and I'll have to do a complete write up here when I have the conversion sorted. |
#16 |
Which model Quaife? I've got the QDF15E in my hatch. The track car (Project 2ZR Vios) has a Cusco clutch pack and it's too aggressive for daily/street use in my opinion. Lots of clunking and banging at low speeds before it gets warmed up.
Is the ECU just a matter of pins being in the wrong place or are there whole systems that are electrically incompatible? I forgot to look at the connectors when I was at the junk yard last month. Any chance you've looked at a 3ZR swap? Looks like you may have access to the 3ZR-FE, we only have the 3ZR-FAE. |
#17 |
The Quaife in mine is a QDF29E. How's your experience with the Quaife been? This will be my first FWD car with one. I'm hoping for a noticeable difference. Even on the street, and especially in the wet, I find the Yaris struggles with traction (195 tyres).
Regarding the ECU differences, unfortunately it's not just a matter of the pins being different - I'm having to build a little patch harness to get around that problem. Even with a ZRE18X ECU, while the dash cluster will work correctly, the Yaris ABS unit won't talk with the ZRE18X ECU. The ZRE18X ABS unit must be used to overcome this problem (Credit goes to another mate of mine for solving that one). Even Adam, who did the Valvematic conversion, had the same issue. I have investigated the 3zrfe conversion and it's tempted me on multiple occasions. We got the 3zr in our Rav4, which conveniently came in manual transmission as well. While I think it'll work, I just can't justify it. The cost of the motor is twice the price of a 2ZR. There's also some trade offs it would seem - you sacrifice rpm for a longer stroke, more torque, and that torque band moved further down in the rpms. I think it'd make for a great little round the town car with the extra torque, but I'm not convinced it'd be as fun in the hills and on the track. Change my mind though :) it's not too late. |
#18 |
I've been very happy with it. No noise, very good traction in the snow and on ice with appropriate winter tires. Not torque steer on hard acceleration. Wet roads are still not great but it's better than an open diff for sure.
Aah, that's a bummer. I work in automotive and see that kind of incompatibility all the time, even on revision changes within a product family. I made a spreadsheet to verify the Yaris and xD ECU pinouts and they're basically identical. The Corolla is way off and requires a lot of pins to be moved/added/deleted but in theory would work. Our workaround for the speedo was to use the C50 turbine and add the wires into the xD harness (since the xD uses the ABS sensors and CAN to send the speedo signal to the cluster). If your differential can use the OEM speedo driving gear and your casting has the hole for the turbine in it, you may be able to go that way. ArmstrongRacing and I had talked about the 3ZR lower/long block as a potential "stroker kit" for the 2ZR, mostly because we only have the -FAE head and that requires a LOT more work to make it run on the Yaris platform. I hadn't considered the tradeoff of stroke length (which is where the extra 200 cc's come from) vs RPM and where the torque falls in the power curve. For race applications, it might be better to keep the torque and power peaks closer together. My racing class would also require additional weight if I went to the 2.0L engine, possibly negating or negatively offsetting the 10-15 bhp gains. And I'd have to use the FAE head, so that's probably not happening. |
| 3rd Gen Gauge Cluster Swap :D | KenTK808 | Third Gen Yaris General Discussion | 22 | 10-21-2017 07:58 AM |
| 3rd gen header? | KenTK808 | Third Gen Yaris General Discussion | 2 | 01-16-2017 02:25 PM |
| Asking a quick favour from 3rd Gen Owners | kuveris | Third Gen Yaris General Discussion | 9 | 03-16-2016 12:08 AM |
| How to clean dash instrument panel? 3rd gen | Tgawe | DIY / Maintenance / Service | 4 | 10-11-2015 05:09 PM |
| 3rd gen 1zz tb swap | mr_miles | DIY / Maintenance / Service | 26 | 05-01-2013 08:20 AM |
