Old 10-05-2020, 02:16 AM   #11
stidnam
Drives: Starlet
Glad I'm inspiring someone :)
You'll likely find that the chassis mounting points for the C5X and C6X boxes will be pretty similar or at least have bosses in the right spot to tap. Would pay to do your research though.
The EC6X boxes will unlikely bolt in to the NCP9X or NCP13X chassis while mated to the 1NZ unless you went custom mounts. I was mulling this over myself when I found out my 2ZR was going to be incompatible with the NCP131 - I wanted to make sure I could still use my EC6X box with the Quaife. However, I've since acquired yet another Corolla/Scion IM, which I know for a fact will work, and am now in the process of piecing all that together. The 2zr dream lives on.
For the record, anyone considering doing a 2ZR swap in to a 3rd gen should probably think twice before committing to it. You must use a 2ZR and some of the other gear from a ZRE18X (Corolla/Scion IM). It's no where near as simple as the NCP9X swap.
stidnam is offline   Reply With Quote
3rd Gen Gauge Cluster Swap :D KenTK808 Third Gen Yaris General Discussion 22 10-21-2017 07:58 AM
3rd gen header? KenTK808 Third Gen Yaris General Discussion 2 01-16-2017 02:25 PM
Asking a quick favour from 3rd Gen Owners kuveris Third Gen Yaris General Discussion 9 03-16-2016 12:08 AM
How to clean dash instrument panel? 3rd gen Tgawe DIY / Maintenance / Service 4 10-11-2015 05:09 PM
3rd gen 1zz tb swap mr_miles DIY / Maintenance / Service 26 05-01-2013 08:20 AM
