Corrosion Block spray rubber bushings creak squeak noise
Could steering noise be rubber creaking...maybe at the ball joint cover or something at the top of the strut? I'm pretty sure my Corrosion Block spritzing made some suspension creak go away, and now I'm hitting everything rubber or plastic (white sway bar bushings). Just my experiment...not advice.
#2 | |
#3 | |
Concerned. Yes. On a couple prior vehicles I was lubing rubber bushings w/ DOT5 brake fluid. (Silicone) Here my thinking was that silicone sprays had other stuff besides silicone in the formula that could hurt "rubber." Results? Don't know for sure. Don't know what's in it and just went w/ Corrosion Block because of what was on their web site. Marketing towards spraying everything under the covers of outboard motors used in salt water...which includes wiring, etc. Main purpose for me was rustproofing w/o hurting wiring, electronics and rubber tubing...notice some some of this around Yaris fuel tank. An experiment. Stuff doesn't smell bad...sort of interesting, actually. |
#4 | |
| Engine turns over but doesn’t start on a Yaris VVTi | YarisVVTi2002 | DIY / Maintenance / Service | 50 | 03-30-2025 08:27 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
| Engine goodies for the Yaris | botchilah | Performance Modifications | 8 | 01-28-2009 09:52 PM |
