Old 01-19-2019, 08:17 AM   #10
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by dogsridewith View Post
Could steering noise be rubber creaking...maybe at the ball joint cover or something at the top of the strut? I'm pretty sure my Corrosion Block spritzing made some suspension creak go away, and now I'm hitting everything rubber or plastic (white sway bar bushings). Just my experiment...not advice.
Are you not worried about the potentially adverse reactions between rubber/plastic components and a petroleum based product? It probably wouldn't hurt anything in the short term, but long term exposure could cause crumbling, swelling, distortion of bushings/other rubber parts etc. I've definitely seem that happen and have caused it myself before I became attuned to it and now try to avoid direct contact.
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
