Old 01-19-2019, 10:17 AM   #1
dogsridewith
Drives: 2007 2-door hatchback
Are you not worried about the potentially adverse reactions between rubber/plastic components and a petroleum based product? It probably wouldn't hurt anything in the short term, but long term exposure could cause crumbling, swelling, distortion of bushings/other rubber parts etc. I've definitely seem that happen and have caused it myself before I became attuned to it and now try to avoid direct contact.
"What...me worry?"
Concerned. Yes. On a couple prior vehicles I was lubing rubber bushings w/ DOT5 brake fluid. (Silicone) Here my thinking was that silicone sprays had other stuff besides silicone in the formula that could hurt "rubber." Results? Don't know for sure.
Don't know what's in it and just went w/ Corrosion Block because of what was on their web site. Marketing towards spraying everything under the covers of outboard motors used in salt water...which includes wiring, etc. Main purpose for me was rustproofing w/o hurting wiring, electronics and rubber tubing...notice some some of this around Yaris fuel tank.
An experiment. Stuff doesn't smell bad...sort of interesting, actually.
Old 01-19-2019, 11:15 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by dogsridewith View Post
"What...me worry?"
It's probably great stuff for rustproofing. I've been trying to nail down a strange rumble I get when my '08 hits dips on the highway. I found a crumbling trailing arm bushing and I had inadvertently hit it a few times with oil-based goop. The core of the bushing is solid, but I pulled off chunks of the bits of rubber that extend to outer part of the bushing. I'm just a little cautious now, I guess. Also, in the past, I ruined a few door gaskets as the thin oil-based stuff I used dripped down, swelling them.
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
