Old 01-19-2019, 10:17 AM   #11
jowii
Drives: 2017 Yaris
Originally Posted by tmontague View Post
A creak I'd nothing serious and likely is a rubber bushing in the suspension. That said if you cannot or do not do the work yourself, it was add up to a costly fix. If you do the work yourself then it's relatively cheap.
Could be something as simple as sway bar bushings, but like I said this isnt a common issue on 2nd gen or 1st gens and this is only a 2 year old car we are talking aboht
Thanks. The dealership drove it around and said they compared it to other vehicles and said it was similar... I called Toyota's main customer support and they couldn't give an answer and they told me that they leave it to the dealer to decide. I asked if since I have a ticket created for the concern, if it would be honored under warranty if it does become an apparent issue after the warranty expires, and I think the answer is no...
I've attached an audio file with what I'm hearing (startup and then steering about halfway through until end). Unfortunately when I record a video with my phone, the cheap phone mic and audio compression in the video make it sound much worse than it is.
Some folks tell me it sounds like power steering fluid being low, which the Yaris doesn't have right? Or maybe it's just a noisy EPS motor or things are easier to hear in the Yaris. Which by the way, when I'm driving around I do find myself freaking out more than I did in my other car, because everything starts to sound like it's coming from the car (other people's cars, the texture of the road, etc.) lol
File Type: zip Yaris-startup-and_steering_sound.wav.zip (1.43 MB, 21 views)
jowii is offline   Reply With Quote
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
