Old 01-21-2019, 03:03 PM   #1
tmontague
tmontague's Avatar
5w30 should be fine, but there is no way of really knowing if you exceed factory specs without knowing oil temp and/or pressure. None of which is available without an aftermarket gauge.
The only way going to a heavier weight oil makes sense is if you are operating above 212F oil temps, or if you want to reduce oil consumption and you notice it helps. You could try a 10w30 as they are slightly thicker than a 5w30 and potentially may reduce oil consumption. The difference between a 5w30 and a 10w30 isn't very big however as they both have to fall into the same viscosity spectrum at 100C. Most 10w30's are a big thicker at 150C due to a higher HTHS rating but like I said, it may not be noticeable enough for consumption issues.
Old 03-24-2019, 04:51 PM   #2
ojeysky
Drives: Sedan Yaris 2010
My oil will be due for a change in 2 weeks after adding the last litre of synthetic. I have tried looking for a conventional 5w30 or 10w30 with no luck. Am wondering if a semi-synthetic of 5w30 will not burn. Any thought?
ojeysky is offline   Reply With Quote
Old 03-24-2019, 04:58 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
What does the engine refill cap say?
Typically, oil weight tend to be quite heavy in tropical countries..
What oil is available in your country?
Old 03-25-2019, 02:58 AM   #4
ojeysky
5w30, 0w20, 0w40 all synthetic and semi-syn
Then we have 20w50 conventional, am told using this causes sludge and reduces engine performance. It's 5w30 on the engine cap and the car is USA spec
Old 03-25-2019, 02:19 AM   #5
B.B._07
Drives: 07 5dr
Short answer is no, oil burning is a symptom of engine wear (most likely worn piston rings). You can try to minimize the running by running a thick oil like 20w50 but the downside in somewhat lower fuel economy. Maybe look for a non synthetic 15W40 or 10W40.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 01:46 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
