Old 03-24-2019, 04:51 PM   #19
ojeysky
Drives: Sedan Yaris 2010
Originally Posted by tmontague View Post
5w30 should be fine, but there is no way of really knowing if you exceed factory specs without knowing oil temp and/or pressure. None of which is available without an aftermarket gauge.
The only way going to a heavier weight oil makes sense is if you are operating above 212F oil temps, or if you want to reduce oil consumption and you notice it helps. You could try a 10w30 as they are slightly thicker than a 5w30 and potentially may reduce oil consumption. The difference between a 5w30 and a 10w30 isn't very big however as they both have to fall into the same viscosity spectrum at 100C. Most 10w30's are a big thicker at 150C due to a higher HTHS rating but like I said, it may not be noticeable enough for consumption issues.
My oil will be due for a change in 2 weeks after adding the last litre of synthetic. I have tried looking for a conventional 5w30 or 10w30 with no luck. Am wondering if a semi-synthetic of 5w30 will not burn. Any thought?
ojeysky is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 01:46 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
