#1 | ||||
Sure enough, when looking at my own Off Road Yaris project, I found some Jeep JK front spacers that may work in the rear of the Yaris. Some measurements were taken, and I *think* they could work. I bought them but never put them on to confirm. I'm pretty sure of it, though. Quote:
If you YouTube "off road yaris" mine should be the first hit. You can see where having an LSD would have helped. But in reality, that stuff I was attempting there IS a bit much for a FWD econobox :) I knew this going in! It did much better on regular dirt trails. I really hope you get this project going!!!! I still go back and forth on mine. Also, I'm still kind of tinkering with a way to get the rear lifted, without affecting the shocks, or the angle of the rear beam assembly. |
#2 | |
![]() ![]() ![]() Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
I have just a little bit of fab left on one front lift and I'll be ready to install. If I can swing a couple hours in the evening this week I'll get them installed. The rear lifts came and look promising. If the centers end up to wide, I'll cut those out and the outer cup walls should still keep them in place. Then I will drive it a few times to make sure all is ok noise/vibration wise. If good I'll cover a current wheel tire in foam/cardboard to make it the sized of the new tires and see if it fits in the wells. I'll need to compress the shocks/struts and still turn the wheels to see if they rub. I think I have enough stands and jacks to manage that. I'll post up pics when I do it. |
#3 | |||
If you're just looking at some old logging roads, maybe a less aggressive "all terrain" may work. But then again, the black Overlanding Yaris guy is running 215/75-15 which is about 27.6" tall. Not sure what his "lift" specs are, but it looks like he's having success with them. Looking forward to your update. |
#4 | |
3 Yaris and counting..
#5 | |
Seems, there's one trade off or another, right?The other idea I had, adds maybe about an inch of clearance without affecting anything else. Anyway, here's the link to using the upper bolt hole. Surely, it is threaded. http://www.yarisworld.com/forums/sho...3&postcount=25 |
#6 | |
Edit: you'd definately want to put some shock extensions of the same length as well. |
#7 | |
I think the 'penguin spacer bearing relocation plate' would be a good idea to get your lift and maintain axle angle + maintain good ground clearance but the only thing I'd be worried about is lateral force. Maybe some sort of diagonal bracing from the bottom of the bearing mount to somewhere on the axle could be fabricated. I looked at fabricating my own spacers but came to the realization it's not easy cutting perfect holes in 1/4" and up thick steel plate and abandon the idea. Side note: I just may be able to get off early enough to pick up my rear spacer bits tonight. I'm having an unforseen issue though and may not be able to fabricate/install the lift for a couple months. Bummer.
#8 | |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 03:13 AM |
