#1 | |||
If you're just looking at some old logging roads, maybe a less aggressive "all terrain" may work. But then again, the black Overlanding Yaris guy is running 215/75-15 which is about 27.6" tall. Not sure what his "lift" specs are, but it looks like he's having success with them. Looking forward to your update. |
#2 | |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
#3 | |
Seems, there's one trade off or another, right?The other idea I had, adds maybe about an inch of clearance without affecting anything else. Anyway, here's the link to using the upper bolt hole. Surely, it is threaded. http://www.yarisworld.com/forums/sho...3&postcount=25 |
#4 | |
![]() ![]() ![]() Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
Edit: you'd definately want to put some shock extensions of the same length as well. |
#5 | |
I think the 'penguin spacer bearing relocation plate' would be a good idea to get your lift and maintain axle angle + maintain good ground clearance but the only thing I'd be worried about is lateral force. Maybe some sort of diagonal bracing from the bottom of the bearing mount to somewhere on the axle could be fabricated. I looked at fabricating my own spacers but came to the realization it's not easy cutting perfect holes in 1/4" and up thick steel plate and abandon the idea. Side note: I just may be able to get off early enough to pick up my rear spacer bits tonight. I'm having an unforseen issue though and may not be able to fabricate/install the lift for a couple months. Bummer.
#6 | |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 03:13 AM |
