Old 02-04-2019, 06:52 PM   #1
myfirstyota
3 Yaris and counting..
Originally Posted by justjesus View Post
I had two ideas for that. (1) Where the beam ties into the body, one bolt on each side if I recall. There are actually two bolt holes on either side. Some guys use the upper one once they've lowered the car some. I was thinking using those two bolt holes to make a simple bracket to drop the beam a small amount.
I also looked at the upper holes to use to mount some type of drop bracket. Now, I didn't spend an hour poking around down there but I didn't think the upper holes were threaded on the inboard side. And because of the way the "frame" is assembled, theres no access to the other side without cutting holes. Please tell me I'm wrong and that the upper holes are threaded on the inboard side (like the lower holes where the axle mounts from factory). If they are... drop brackets would be very feasable. But then I think, you axe some ground clearance by lowering the whole axle...
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 02-05-2019, 01:05 PM   #2
justjesus
justjesus's Avatar
Drives: 2008 Liftback
You would definitely lose some clearance. Seems, there's one trade off or another, right?
The other idea I had, adds maybe about an inch of clearance without affecting anything else.
Anyway, here's the link to using the upper bolt hole. Surely, it is threaded.
http://www.yarisworld.com/forums/sho...3&postcount=25
Old 02-05-2019, 01:31 PM   #3
Maritime
Drives: 2008 yaris 5dr hatch
interesting. so the 2 holes could be used with some plate to do the opposite and lower the axle an inch to correct for taller springs and keep travel the same. Very interesting indeed. mind you would lose a little clearance but keep factory set travel.
Edit: you'd definately want to put some shock extensions of the same length as well.
Maritime is offline   Reply With Quote
Old 02-05-2019, 01:34 PM   #4
myfirstyota
That would appear to be threaded for sure lol
I think the 'penguin spacer bearing relocation plate' would be a good idea to get your lift and maintain axle angle + maintain good ground clearance but the only thing I'd be worried about is lateral force. Maybe some sort of diagonal bracing from the bottom of the bearing mount to somewhere on the axle could be fabricated.
I looked at fabricating my own spacers but came to the realization it's not easy cutting perfect holes in 1/4" and up thick steel plate and abandon the idea.
Side note: I just may be able to get off early enough to pick up my rear spacer bits tonight. I'm having an unforseen issue though and may not be able to fabricate/install the lift for a couple months. Bummer.
Old 02-05-2019, 01:38 PM   #5
Maritime
Ha I just typed my reply before I saw this. I know a guy stateside with a CNC water jet that could cut anything we could draw up.
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
