Old 02-05-2019, 02:10 PM   #1
scion xb gen1 springs: LIFT IT. LIFT IT GOOD!
Old 04-16-2019, 10:24 PM   #2
YarMatey
Drives: 2008 Toyota Yaris 5dr Liftback
With just the xD springs how much lift would you estimate it gave you? Any issues with the shocks being topped out that you noticed?
Also, Myfirstyota you said the whole strut assembly from an xD will bolt right into a Yaris with no modification? What about the rear shocks do you know?
Hot Rhonda
- Bayou Blue
- Cosmo Racing Short Shifter
- Kenwood Single DIN Aftermarket Headunit
- Rockford Fosgate Punch 6.5” Speakers
“the dents make her handle better.”
YarMatey is offline   Reply With Quote
Old 04-23-2019, 04:31 PM   #3
myfirstyota
3 Yaris and counting..
I'd say an inch to an inch and a half. And yes, you must be careful when going over speed bumps etc. When the suspension dropps out. Because there is much less weight, the struts top out quick. Daily driving is no problem. But if you take a speed hump quickly, the struts will top out.
And yes, theyre a direct bolt-in. You could order an aftermarket assembled strut and you're done.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
