Old 02-06-2019, 08:30 AM   #1
dogsridewith
Drives: 2007 2-door hatchback
Yaris idle speed measure multimeter frequency
Manual tranny warmed-up idle is 600 rpm. Mine was, and likely is, exact, per a multimeter set on "frequency" standing up in the driver's side dash cupholder. (Yes, that isn't a little glove-box as it might seem...notice how it will crush contents when closing.)
Old 02-06-2019, 11:29 AM   #2
Phatdonkey78
Drives: 2007 Hatch
I saw this the other day, but can't remember where I saw it. I need to know which pin on the OBD connector to connect the positive lead to. I love the idea of using a multimeter as a tach! Also, when you say frequency I'm assuming you mean volts AC.
Phatdonkey78 is offline   Reply With Quote
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Erratic/High Idle twitchyboy DIY / Maintenance / Service 11 11-22-2015 12:14 PM
Idle or Power Problem? duendeverde DIY / Maintenance / Service 11 12-13-2014 03:08 PM
Fix For Low Idle When Warm On A Yaris Mk1 danielbb DIY / Maintenance / Service 0 06-12-2014 04:13 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
