Old 02-10-2019, 08:25 AM   #1
2bz
Drives: 2008 Yaris 3DR Hatch MT
OP: Have you:
1. Cleaned the idle air control valve (under the TB)?
2. Cleaned the VVT oil control valve?
3. Replaced the oil control valve filter?
2bz is offline   Reply With Quote
Old 02-10-2019, 11:16 AM   #2
Phatdonkey78
Drives: 2007 Hatch
Originally Posted by 2bz View Post
OP: Have you:
I haven't done any of that yet. I'm planning on taking the TB off today and rooting around in there. I assumed there was no IAC due to it being throttle by wire.
I do have another question. If the TB is removed from the vehicle, can the butterfly be moved slowly to clean the back side of it and the edge? I have seen videos and forum posts saying it's ok to do so, while others say to never manipulate the butterfly EVER. I won't be flipping it rapidly, just slowly open it to clean it thoroughly, while trying to not strip the gears inside.
Phatdonkey78 is offline   Reply With Quote
Old 02-10-2019, 11:28 AM   #3
2bz
No IAC on this model. Sorry, my bad.
Old 02-16-2019, 08:03 PM   #4
Phatdonkey78
Drives: 2007 Hatch
Today I got the throttle body gasket and got to work. Removed the TB and cleaned it front and back. Installed new gasket and slapped it all back together. It is a lot more responsive and the stumbling idle when braking is gone now.
Next task is passenger lower control arm replacement. Went to get an alignment and the ball joint is mangled pretty good.
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Erratic/High Idle twitchyboy DIY / Maintenance / Service 11 11-22-2015 12:14 PM
Idle or Power Problem? duendeverde DIY / Maintenance / Service 11 12-13-2014 03:08 PM
Fix For Low Idle When Warm On A Yaris Mk1 danielbb DIY / Maintenance / Service 0 06-12-2014 04:13 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
