Old 02-10-2019, 08:56 AM   #1
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Just a good advice, start with changing the oil to original 75W GL4 as i adviced you to do.
You have put in a GL5 oil and that is against Toyotas recommendations.
It has been discussed a lot on the danish Toyota forum, and there is also many who has tried other oils with poor result/shifting.
And when they finally give up other oils and put the right oil in then they admit that solve the problem.
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 02-10-2019, 12:00 PM   #2
cylaptor
Drives: Yaris 1.3 VVTi R&B
I do not know, but the same problem was also present before changing the new oil. Although I think that the first oil was still original and 10 years old. Mobil1 is superior oil and has the same specification GL4/5 75w-90, and it is a fully synthetic. I think the problem is something else, I'll explore. I will also change the firmer bushing on the end link of gearing cable, because there is now some 3 mm empty walk and the shifting is not so precise.
cylaptor is offline   Reply With Quote
Old 03-03-2019, 03:03 PM   #3
cylaptor
thanks, we solve the problem with the the original toyota gear oil 75w GL4 !
Idle issue on 2007 Yaris 1.3 VinceSA DIY / Maintenance / Service 10 12-09-2020 11:43 AM
P0705: Yaris 2008 stuck in first gear in D position eepp DIY / Maintenance / Service 3 01-22-2018 11:24 AM
2007 Yaris Sedan Squeaky 2nd Gear Omardavila1997 DIY / Maintenance / Service 2 08-24-2017 07:32 PM
When to go from 1st to 2nd to 3rd and so... yaristhebest Fuel Economy Forum 30 01-15-2013 05:32 AM
Strugeling 1st gear!!?? mhkritzinger DIY / Maintenance / Service 15 02-06-2010 10:25 AM
