Old 02-17-2019, 08:34 AM   #1
2bz
Drives: 2008 Yaris 3DR Hatch MT
Looks good! The tolerance between the butterfly and the bore on the TB is DNZ (damn near zero), so this should certainly help. I have installed an oil catch filter after the PCV and now my TB stays squeaky clean.
2bz is offline   Reply With Quote
Old 02-17-2019, 12:41 PM   #2
Phatdonkey78
Drives: 2007 Hatch
How often do you drain the catch can? Did you buy one or make your own?
Phatdonkey78 is offline   Reply With Quote
Old 02-17-2019, 01:49 PM   #3
tmontague
tmontague's Avatar
I drain mine every week (approx 150 km) and 3-4 ounces come out during the middle of winter. In the summer it is mostly oil and little water and I drain it much less
Probably around 4 ounces every 6-10k km
Old 02-17-2019, 02:49 PM   #4
2bz
I spliced this compressor air filter in with a couple of 3/8" barbs.
https://www.harborfreight.com/mini-a...ter-68225.html
https://www.harborfreight.com/38-in-...ece-63957.html
Old 02-17-2019, 02:56 PM   #5
2bz
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Erratic/High Idle twitchyboy DIY / Maintenance / Service 11 11-22-2015 12:14 PM
Idle or Power Problem? duendeverde DIY / Maintenance / Service 11 12-13-2014 03:08 PM
Fix For Low Idle When Warm On A Yaris Mk1 danielbb DIY / Maintenance / Service 0 06-12-2014 04:13 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
