2ZR swap. DO IT! Ask how!
I thought that the solenoid replaced the Bendix by using a lever arm instead of a threaded interface to extend/retract the pinion. Mostly being a nitpick, but curious if I've misunderstood something. =)
#2 | |
However, it uses a screw type gear that you see in an inertia type starter that doesn't use a solenoid. I'm not exactly sure why the worm type/bendix gear is used on top of the solenoid, I've been trying to wrap my head around it for a while. All I know is that when it is not lubed and it is gunked up it stops the pinion from engaging as you would see in a typical inertia type starter. It seems as if the yaris starter is a combo of the 2 types for what ever reason
| follow up on 2010 yaris problems + more problems | heavenswaitin | DIY / Maintenance / Service | 18 | 09-03-2013 03:47 PM |
| Starter (or possibly electrical) Problems with 2008 Yaris Sedan | amandadalton | DIY / Maintenance / Service | 6 | 11-21-2012 05:32 PM |
| starter kill & horn help | spechuy | DIY / Maintenance / Service | 0 | 10-20-2008 01:30 PM |
