Old 03-02-2019, 01:23 AM   #1
tamrat
Drives: 2009 Yaris, 1994 HiLux Surf
All fixed up.
I hooked up a multi meter to the cable that carries power to the fan and noticed that it was getting voltage (12V and 24V; I assume this is how the fan can spin in two modes). That meant the system was working and the fan motor was the problem. When I wiggled the terminals the fan came on and off. So it was definitely a loose connection inside the motor.
New OEM replacement fan motor goes for around $260 here. So I decided to rebuild it. Took the motor apart, cleaned it up, tightened up the terminals and also changed the brushes because they were worn down to the lowest point. Everything works perfectly now. And it cost me the equivalent of $2. :D
The Surf is still here.... But now there is a Yaris next to it!
tamrat is offline   Reply With Quote
Tags
fan, overheat
Cooling Fan Not Running silverswitch DIY / Maintenance / Service 15 03-08-2021 02:05 AM
Radiator fan doesn't start when the engine gets hot jackmilas DIY / Maintenance / Service 6 10-20-2016 01:27 AM
A/c fan operation. mrpj Third Gen Yaris General Discussion 1 03-29-2015 06:57 AM
No power to engine fan ihateyaris DIY / Maintenance / Service 2 03-26-2015 06:33 PM
Fan Not Spinning Up, Random Airbag Light drannonb DIY / Maintenance / Service 12 10-23-2012 03:33 PM
