Old 03-06-2019, 02:59 PM   #1
dogsridewith
Drives: 2007 2-door hatchback
Doesn't the MAF sensor have to survive everything gaseous coming up from the crankcase and through under the valve cover?
Old 03-07-2019, 07:55 AM   #2
2bz
Drives: 2008 Yaris 3DR Hatch MT
No. The MAF is before the intersection where the crank case gases enter..
2bz is offline   Reply With Quote
Old 03-07-2019, 08:47 AM   #3
dogsridewith
Then what gets it dirty?
Old 03-07-2019, 11:47 AM   #4
There are still fine particulates that get through an air filter. This very slowly over time accumulates on the fine wire in the maf.
Sent from my EML-L09 using Tapatalk
Old 03-07-2019, 04:27 PM   #5
2bz
Also, depending upon the MAF design one wire is heated, like a toaster element and can burn said particulates, which stick to it. This is why you don't want to clean the MAF with anything that leaves a residue. It will burn on too and give incorrect data.
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
